Linksys Wireless-G WRTP54G Router Logo
Posted on Aug 02, 2011
I used to have an option in my linksys admin page to enable UPnP... Then a technician came in to fix some problem i was having with my wireless router and i think he updated the firmware of my WRTP54G to firmware 12.0.1-r110407-3.7.2. It used to have a blue and white layout on my admin page and now it is kind of black and yellow and there is NO option to enable UPnP. Is there a way to revert back to that blue and white layout firmware version where UPnP was available?
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on Dec 30, 2007
SOURCE: I Upgraded RV042 to latest firmware from Linksys Site and now Router Continually reboots
i think there might have been some sort of virus(spyware, adware, trojan)
Anonymous
  • 813 Answers
  • Posted on Feb 26, 2008
SOURCE: BEFSR81 admin problem when enabled uPNP
in the router has one rest pin just press it for 3 min then after try to logged in but remind u have to configer agin
defolt ip is 192.168.1.1
user: admin
pass:admin
try it
Anonymous
  • Posted on Jun 16, 2008
I actually FOUND the solution at the linksys community forum site. It's weird, and I quote [kiefmoon], "I beat my head against this issue for the past few months, for the same reason as you: I'd built out a Windows Home Server, which can configure a home router automatically via UPnP, so I happily enabled it on the router, only to be locked out of the web-based configuration page.
Good news though! I just figured out the cause of the issue -- and it's really dumb:
You turn on UPnP on the Passwords tab, right? Well, if you look around on that page, you'll notice that, along with the option to enable UPnP, there are two password fields filled with asterisks. I think most people would assume that if they don't change anything in those fields, then click Apply, that the password has not been changed. And they'd be wrong. I don't know what the password gets changed to at that point, but it's not "admin".
...So the fix is: when you enable UPnP, do yourself a favor and enter a password in those fields (ideally something sronger than "admin" ). That way, you'll actually know what the password is when you get prompted for it."
Anonymous
  • 1913 Answers
  • Posted on Jan 05, 2009
SOURCE: WRTP54G not routing
turn the power off for 5 minutes then try.
if still pro let meknow.
Anonymous
  • 104 Answers
  • Posted on Jan 14, 2009
SOURCE: Cannot find wireless tab on Linksys router setup page
Hi...this is an unusual problem.
Is your model the BEFSR41W? Linksys describe this as a 'wireless ready router', and it seems to require a PCMCIA card to be inserted in the back of the router, to enable wireless connectivity.
I'm just wondering if the router lost communication with the card, causing your wireless options to disappear?
However, first things first. As you have (correctly) reset the router, all your settings have been cleared, including ISP information (hence the internet connection is lost). Your first priority is to set up your router again, and the Linksys website has a downloadable manual, quick install guide and tips which will help with this.
When you are up and running - and assuming I have the right model - try removing and re-inserting the PCMCIA card at the back of the router, and see if the router re-detects it. If successful, this should bring back your wireless options.
I hope this helps, but please post again on Fixya if not. It does seem odd to have lost the wired connection before the reset.
Good luck. :)
How to change to upnp
First, access the GUI of your router. Open browser and type 192.168.1.1, type admin for username and password or if you had change it before, use that username and password that you had set up. Once you see the Linksys GUI page, click on Administration on the upper right corner of the screen and click on management, from there you can edit the UPNP settings.
Linksys wrt54gs changing upnp settings
Hi, you can enable UPnP on a Linksys WRT54GS router by logging in and then clicking on the Administration tab. The first sub-tab is Management, and at the bottom of that page there are buttons to enable or disable UPnP. Click Enable and then click Save Settings at the bottom of the screen.
1helpful
2answers
I have someone using my wifi and would like to know how put a password?
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
4helpful
How do I enable UPnP on this router WRT160N
on WRT160N router UPnP is enabled by default.
You don't need to enable it.
If you want to check the settings of the router then you will need to open the set up page of the router. Router set up page is a page where you can check/change all the settings of the router.
Is there any computer connected to the router. Check the Ip address of the working computer and open the router set up page.
Once you open the router seyt up page, click on Administration Tab. On that page at the bottom you will see UPnP. It must enabled.
Click Here for more information about router and
networking
I have a Linksys wireless 2.4 Ghz Broadband router. I have a secure wireless network set up, but it has a red x through it, and defaults to an unsecured wireless network. How do I fix this?
Access the router setup page from the working computer you can do this by typing 192.168.1.1 on the address bar of your internet explorer and that will ask you for a username and password leave the username blank and password is admin if admin did not work type your commonly use password, Once you're on the setup page you can go to Wireless tab and then Wireless security and there enable the security that you want to use......
15helpful
2answers
Slingbox
Access your router interface page by typing http://192.168.1.1 in the address bar of your browser, the login is Admin password is admin. Click on the "Administration" button on the top right. On the bottom you will see the option to enable UPnP. enable it there and you should be good to go.
Slingbox configuration for remote viewing - How to set up ?
6helpful
2answers
How do I configure UPnP? on my router?
Universal Plug and Play (UPnP) allows discovery of UPnP enabled devices in a network environment. UPnP is only available on Windows Me and XP. If you are not using either operating system on any of your computers, or do not want to use UPnP, then it is recommended to disable UPnP on the router. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Tools tab then click Misc. to the left. Step 4 Under the UPnP Settings section, select Enabled using the radio buttons to enable UPnP on the wireless router, or select Disabled using the radio buttons to disable it. Step 5 Click Apply and then click Continue to save the new settings.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
