The software is already on your computer - check the settings in the properties. If you are unsure how to use these settings, there is ample "help" available by simply clicking the button.
When you lock this up ... you will be putting a password on it. If you forget the password, you will no longer have access to your hard disk - you need to fully understand this before you go on. If you are not sure, DONT DO IT.
The easiest way to secure your external drive from others is to disconnect it from your computer.
Thank you for your question @ FixYa.com
A hard disk drive may be come locked or unlocked allowing or not allowing for software to have direct disk access. You may encounter an error indicating to unlock the hard disk drive in any of the below circumstances.
To unlock the hard disk drive
unlock x:
The x represents the letter of the hard disk drive that you wish to unlock. For example, if you needed to unlock the C: drive, type c in the place of x.
Additional information about the lock and unlock command can be found on our Lock / Unlock page.
To lock the hard disk drive
lock x:
The x represents the letter of the hard disk drive that you wish to lock. For example, if you needed to lock the C: drive, type c in the place of x.
