I have seen this many times, most of the time it's because the index file was writing or cleaning itself when you removed it. This is what the "EJECT" is when you right click. As a matter of course, you should always 'eject' the media before removing it. (It doesn't physically pop the media out, it really should be called "Shut Down Media XXXXX" So in most cases, there's nothing you can do except send it off to a data recovery service and be prepared to shell out a bunch of money.
SOURCE: My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
SOURCE: its not open the 2GB
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
