Follow these steps: 1. Connect the camera to the printer. 2. Turn on the printer. 3. Turn the Mode dial to Playback mode and turn the camera on. 4. Press the (+) button on the camera. 5. Press the up or down button, choose Select images, then press the OK button. Note: If you see the message “Use previous print order selection?” select No, then press the OK button. 6. The images display as thumbnails. Select the first photo to print using the < or > button. 7. Select the number of copies to print using the up or down button, press OK. The screen displays the print settings and the number of copies selected. 8. Press the MENU button to return to thumbnails. 9. Repeat steps 6, 7, and 8 to select additional images. 10. After you select all the images to print, press the MENU button. 11. Press the up or down button to select Print an Album. 12. Select the number of photos per page using the < or > button, then press the OK button. Note: To determine the maximum number of images your printer can print per page see the table below. If you select more images per page than the printer supports, the camera will display the error “This function is not available”.
Directly from HP's manual on this printer:
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
For more assistance with this printer, you can go to http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=441125& and download the owner's manual. It is in PDF form, so you will need adobe reeader which you can get for FREE at http://www.adobe.com
Rose Marotta
PC ICU
Danville, Va 24541
For all your computer repair needs.
