The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
· open Control Panel and select Display menu and open it
· Then select Settings Tab from where you can change resolution and Color quality as 32 bit /64 bit
· ]Or you can click on Advance where you can set DPI
If you want to switch in 256 color
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don
I tried that, didn't help... then I went into BIOS and found out my video buffer was only set to 1MB. >.< Changed it to 8MB, and now I've got 32-bit color at 1280x1024. I appreciate your help either way, thank you.
