Runs rich on high speed or hunts with black smoke
and fine on idle Lets understand it this way whenever there is black smoke that means there is not proper combustion in the cylender head means un burned fuel means less power which is either fuel is not pure due to dust particals or there is not proper current through the spark plug that means fuel is not burning properly and resulting in to smoke in the exoust if you have checked the fuel already then check for the current coil for proper currrent through a wiring diagrame which can possibly make you check up to the inverter level to see if your inver is malfunctioning if its ok then check the air fuel mix screw on the carburator to check that the full oxygen supply is going in the carb for proper combustion try adjusting the air fuel ratio on high speed or on load even than the problem persists check if your spark plug is wet after a brief running if it is dry thsn its fine if it covered and wet with engine oil that means engine oil is comming in to the cumbustion chamber and burning with thr fuel and resulting in to smoke for that matter you will have to check your piston rings
if your
SOURCE: EU3000is running rough and idle hunting.
I'VE SEEN THIS BEFORE ON 1 I REPAIRED IT IS THE INVERTER THAT IS BAD!!! THEY COST ABOUT $600.00 JUST FOR THE INVERTER!!!!
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
