Sony DPP-FP50 Thermal Photo Printer Logo
Posted on Aug 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony DPP-FP50-Colors print in different sizes. Using postcard size, one color (not same color every time) prints with borders while other colors print without borders. Have tried uninstall, re-install printer. When got the printer, had XP on HP. Now have Windows 7 Professional on Acer.
  • tedhank Aug 03, 2011
    None of you suggestions has worked for me. I usually print photos straight from Windows Explorer. I am not allowed to change compatibility there. I tried changing compatibility for Windows Live Photo Gallery but got the same printing problem there. I have uninstalled and reinstalled the printer multiple times. When I try to use the CD that came with the printer, Windows 7 does not recognize anything as a printer driver on that CD. Unless you have any other suggestions, I guess I will have to buy a new printer.
  • tedhank Aug 04, 2011
    At this sitehttp://www.sony-asia.com/support/compati... it indicates the printer should work with Win 7 (does not indicate home or professional, mine is professional 32-bit) with some limited functionality (*2 Instead of the driver supplied with the printer, please use the printer driver available with Windows Update. However, functions such as red-eye reduction and preview are not supported.). I tried that with no success. Unless that gives you any clues that could help, I am ready to move on to a new printer.
Anonymous
Level 3:
Guru:
  • Master 610 Answers
  • Posted on Aug 02, 2011
Anonymous
Master
Level 3:
Guru:
Answers
610
Questions
0
Helped
175489
Points
1784
I was actually a bit surprised that you were able to run it using windows 7. Sony did not release any specific driver designed for windows 7 operating systems and this can cause an issue to printing operations if you have used older drivers. Try running the main printer application on compatibility mode and see if it resolves your issue. Right click on the main application shortcut and click on properties. Go to compatibility tab and choose a lower operating system (e.g. Windows XP service pack 2). Save the changes by clicking on OK and test the printer. If this won't work, I would strongly suggest you uninstall the printer and removed all instances of it in Printers and Devices. Remove all applications associated with it (uninstall). reboot the computer and if the Printer came with an installation CD, used it to setup the printer. Make sure that the printer is plugged off the pc when you run the setup. Plug it only when prompted during the installation procedure. This is important to avoid driver conflicts.
Post here if it works for you or not.
Thanks for using fixya.
  • Anonymous Aug 04, 2011
    Hi there Ted,
    As I told you, I was surprised that you were even able to make prints using a windows 7 machine as this model is not windows 7 compatible. They haven't even released an updated driver for this.
    Unfortunately, it is either you use it on a computer with lower Operating system (windows xp or vista) or buy a windows 7 compatible machine.
    HI there Ted,
    The reason why they said that it can work with limited feature is because Windows 7 does carry a bigger "driver store" which makes it work for most devices "basic functions". But the problem we are having is quite specific, this is not basic functionality anymore, it is specific and these "specific requests" are being handled by software drivers. If we don't have the correct software drivers, these specific requests will not be processed correctly by the printer. I checked everywhere to see if there is a driver available for windows 7 but could not find any, unfortunately.
Why is the sony dpp-fp90 digital photo printer only printing half the picture?
Are you using a large image size, try smaller size file..Its a data processing problem. clear the memory of the printer.If persists it could be a lose data cable in the printer if the printer has had a knock
4helpful
2answers
Cannot find the driver for mac for sony DPP-FP60
Export your photo from iphoto to a usb stick. Then stick that into the printer´s usb port. Use the menu of the printer to make any last corrections (size, brightness, borders etc). Works with both RAW and JPEG. Good luck. /Anders
2answers
Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
Hello
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
TROUBLE PRINTING
These are following cases for this symptom.
If the access indicator flashes in green:
The data size of the image is large and it takes longer to process it for printing. Printing will start as soon as the data processing finishes.
If the paper error indicator flashes on the LCD:
The paper is jammed. Turn off the printer and turn it on again, take out the paper tray, and then remove the jammed paper from the paper outlet. If you cannot remove the jammed paper, consult with your Sony dealer or service facility.
If no indicator is lit or flashing:
The thermal head may be overheated. Leave the printer until the head cools down and the printer resumes printing.
Printing
hello,
probably the printer takes his own color-profiles installed by epson.
Click on propriaties of the printer and create your own color-profile for diferent sizes.
you can take the color-profile from a smaler size and save it choosing an other size.
So You also can improove your pictures by changing the color-profile after your needs...
but then you should use the same paper , because different papers give different colors.
you can also improove the colors by choosing-on the profile-another type of paper.
i hope i could help
1helpful
Printing problem
you may have a faulty Thermal element, sounds like a cold spot in the middle of the print head is messing up your photo. If this is in warranty or is new get them to replace it
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
