SOURCE: washer is leaking water at bottom
You should look at the machine's bottom first- try to find out from where water leaking from. In most cases it is the pump.In such a case it should be replaced. Good luck!
SOURCE: I have a Frigidaire upright
yout drain in the frig. is clogged,find the drain reservoir most times in the back top of frig. remove cover and clear it out with a hanger or shop vac,if ice is there melt it with hair dryer then claer out,hope this helps,thanks-mike
SOURCE: Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
SOURCE: Frididaire side by side refrigerator- water freezing in bottom
Frozen or Plugged Defrost Drain
On Side By Side Refrigerator
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models the pan is accessible without removing the back panel and others are not.
Once you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster like this one: Turkey Baster http://www.repairclinic.com/SSPartDetail.aspx?PartID=428708&PPStack=1
To squirt hot water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
SOURCE: SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
