My refrigerator makes loud noises eminating from the back of the unit. These noises last for 5-10 seconds and then stop. This happened for a few weeks and then the refrigerator stopped cooling, my freezer went out and water pooled on the floor. A day later my freezer and refrigerator were working again and worked fine for 2 months. Then the noise came back and the refrigerator stopped cooling again. Does it sound like the compressor went out? I have water dispenser but the water line if not connected to the refrigerator. Could this be causing a problem? Should I buy a new unit or is it worth it to have it fixed?
SOURCE: refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
SOURCE: water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
SOURCE: water pooling on the bottom shelf of the freezerless refrigerator
take back panel off inside freezer.
you will see a drain tray at the bottom with a drain hole in the middle. this hole is blocked with ice
melt off with a hairdryer and follow up with hot water till water flows away freely.
check drain tray heater is ok as well
SOURCE: Why does my freezer work but my refrigerator doesn't?
1.Check to see if the T-stat is closing the circuit to the circulating fan that blows the air into the refrigerator.
2. Chek the fan motor for proper operation.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
The fan is hitting on ice buildup...
Check out these tips...they can help you figure out what
is going wrong withyour refrigerator
Refrigerator
not Cooling or Fridge not Cooling
How to Defrost
Timer Problem
Water
Running in refrigerator from Freezer
Refrigerator
heatman101
