It gives the error code c3451 when i send a work to print
The code is for fusing warm up failure. Turn the machine on, wait for the error, then open the front door - you will see a cover on the right hand side which you need to unscrew and remove, behind that is a board (PWB-S1- Tech. Rep. Setting Switches Board) press the trouble button then reinstall the cover and shut the door. Your printer should now reboot - if the error comes back you will need to have the fuser either repaired or replaced.
Copy redusing from adf
the front door you're talking about, is that the one covering the toner and the counter?
how to clear that error
