In the display shows any error message?? Also Confirm the model of the equipmentIn the display shows any error message?? Also Confirm the model of the equipment
You can't post conmments that contain an email address.
That is the master clamper area. Take off the rear cover. From the rear it is on the right. There is a motor and a rack gear that moves to open the drum master clamper when removing and loading a master. With the back cover removed, try to make a master while watching that assembly. You can also put the drum in and drive the motor by hand to watch and see if opens the drum clamper.
Hi, Lanier 5618 is not a Network Copier. However, it may be installed on one PC and shared from there. Drivers are available from LANIER Official Support
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Set the maintenance counter:perform test command 72.Press C - interrupt key - 0 - interrupt key - 7 - 2 - PSW.The currently set maintenance cycle code is displayed and the ready lamp lights up.After the ready lamp lights up anter the set code corresponding to the maintenance cycle mode.0 = 10000 sheets ; 1= 15000 sheets ;2=30000 sheets.See the toner full detection part and remove the wastw box,change it.Perfor the test command 14.This command used to cancel troubles other then U1 and U2.After cancellation of trouble the test command is also cancelled automatically,also used to cancel toner full detection the maintenance lamp blinking.
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Press "clear/stop" and "8" at the same time. An error code will be displayed as long as these two buttons are held down. What is the error code? Let me know, please.
The maintenance time is flashing.To be use the service enter code C-0-0-C or C -Interrupt-0-Interrupt,then press 20(maintenance counter clear) and 72 maintenance preset counter setting for a new value.
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
