1. You must start with the headset in the OFF position. Put the headset in pairing mode by Pressing and holding the Multi-Function Button until the lights are flashing alternating Red and Blue, you will then release the Multi-Function Button. Please note the headset will continue flashing Red and Blue until the paring cycle times out (approximately 2 minutes) or completes the paring with the cell phone. If you only press and release the Multi-Function Button the headset will not go into the paring mode. 2. Once the headset is in paring mode, go to the Bluetooth menu / connections of your cell phone. Select add new / search for / find new device (different phones have different but similar names for the options). The cell phone should find a device called VXi B250-XT. Move the cursor over the VXi B250-XT and press (OK, select, enter, or whatever your phone uses for a prompt). If the cell phone asks for a passkey code you will put in 0000 (four zero's). The headset will then pair and connect to the cell phone and be blinking Blue once every second. Your phone may ask you if you want to connect to the B250-XT and/or add it to your trusted device list, press (OK, select, enter, or whatever your phone uses for a prompt).
