My phone is a Philips SE635.
The Telephone is flashing a red light and LED screen says
"1 NEW CALL" with an envelope icon flashing as well.
No messages have been left on answerphone and I have also checked messages on the phone via SMS envelope but there are no messages left. Have tried unsuccessfully to delete.
Could you please help? Thanks
my Philips SE635 continually emits a bleeping noise and the phone lights up whilst in the holder. There are no apparent oustanding events on the phonemy Philips SE635 continually emits a bleeping noise and the phone lights up whilst in the holder. There are no apparent oustanding events on the phone
You can't post conmments that contain an email address.
Envelope usually indicated a text message. Usually, if you have unread text messages your little envelope will have a number one or number two, etc in red on it.
You will need to go to your text message icon to open your text message screen.. It might be called *Inbox* but it's not email only text or SMS messages.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Hi the handset for the telephone (philips) is blinking red and the screen indicates to new calls and i ereased all messages and still blinking with a new calls .any one can help me plz? thank you so much
Hello,kindly take off the phone battery for a while and reinsert it back to see if that helps It could be a software problem that hangs the message light there. Wish you good luck. Take care.
If you've just put your SIM card in your Nokia 5800, you may have noticed a flashing envelope icon at the top of the screen.
This icon indicates that the SIM card's own text message storage is full. This doesn't actually cause problems on the 5800 because it stores its messages in the phone's own memory, but the envelope can look a bit annoying.
To get rid of the flashing envelope:
1. On the standby screen press the white menu button.
2. Select "Messaging"
3. Select "Options"
4. Select "SIM Messages"
5. Delete some or all of the messages from the SIM messages folder using the Options menu.
This should make the flashing envelope go away. You only have to do this once because when the SIM card is emptied it won't fill any more, as the 5800 does not store messages on SIM cards.
This is common on the Nokia N79. Your Sim card probably has text messages saved on it and the flashing icon is showing your sim sms memory is full. In the inbox go to the setting and view the sms on the sim, delete them and the message icon should stop flashing.
The red blinking light is an 'event' light, it does not necessarily mean a message is waiting for you, it will also start to flash if you have a missed call.
click 'up' on the round button to show the missed calls list and it will stop flashing, at least it does on mine!
I had this. Very frustrating. I have the manual in French but it doesn't say how to fix this. The solution I found was very simple. Just press the message button on the handset rather than playing with the base. The button that has a little envelope on it!!
THANK YOU VERY VERY MUCH. YOUR SOLUTION HAS SOLVED THE PROBLEM AND THE FLASHING HAS STOPPED!!
FANTASTIC - THANKS AGAIN.
the same as above
the same problem. what can i do?
