No sound on text message tried everything restarting taking battery out all volumes are up on everything nothing works tried highlighting the one i wanted again tried everything whats up with my phone its so annoying help please
If you are unable to operate the phone at then the last option that you can do is to hard reset the phone, please take note that this procedure will delete everything on the phone. Please follow steps below:
Back up data on the internal memory.
Turn off the device.
Press and hold the Volume Up key and the Home key, then press and hold the Power key.
When the Samsung GALAXY GRAND Prime logo screen displays, release only the Power key
When the Android logo displays, release the Volume Up and the Home key ('Installing system update' will show for about 30 - 60 seconds before showing the Android system recovery menu options).
Press the Volume down key several times key to highlight 'wipe data / factory reset.'
Press Power key to select.
Press the Volume down key until 'Yes -- delete all user data' is highlighted.
Press Power hey to select and start the master reset.
When the master reset is complete, 'Reboot system now' is highlighted.
Press the Power key to restart the device.
Have you accidentally turned all sounds off? I'm guessing Volume was turned off somehow.
1) Turn the phone off. 2) Restart phone. Don't touch volume controls yet. 3) go to 'Settings' and find 'Sounds'. Touch 'Sounds'. 4) go to 'Volume' and set every one to the maximum. 5) Call a friend and ask him/her to call/text/message and everything else. Does it work?
If that doesn't fix it, go to the last App or Widget you downloaded to your phone before the problem began and uninstall it. You can always re-install it. Sometimes Apps or Widgets mess with Sound and other settings in our wonderful mobile/cell phones.
If that doesn't fix it, you can always try any retail cell phone store and just ask. Most of them, when they aren't really busy, like to solve problems. They do it all day long.
Good luck.
1. Press 'Menu' (press Navi key). 2. Highlight 'Messaging' and 'Select' (press Navi key). 3. Scroll to 'Message settings' and 'Select' (press Navi key). 4. Highlight 'Text message' and 'Select' (press Navi key). 5. Highlight 'Message centres' and 'Select' (press Navi key). 6. Highlight 'Add centre' and 'Select' (press Navi key). 7. Highlight 'Message centre name' and enter 'O2 SMS'. 8. Highlight 'Message centre no.' and enter the message centerno.(to know your message center no just google it with your network name)
9. Highlight 'Save' and 'Select' (press Navi key). 10. Press 'Yes' (press Navi key) to the question "Set as default message centre".
Do a battery pull by removing the battery, and make sure to give it time to completely boot up. If you are texting while you are receiving messages which is very common, sometimes it eliminates the sound while you are texting because it cannot render the sound while you are a sending a message. If thats not the case, then make sure to go to your sound settings and turn it completely up, if that doesn't work try to apply a different alert ringer for it.
Nokia phones call them "profiles" , a set of preset modes where you can have different volume levels and tones for different occasions i.e General, meeting, loud, silent etc. I was suggesting trying a different preset mode If available to see if it worked for you.
I have had that problem several times.
1)I go to ringtones for text messages and just highlight the ringtone you want again.
-If that doesnt work- 2)I just restart my phone and it seems to come right back.
It tends to happen to me when my phone gets kind of low on the battery.
Go to Profiles, and choose a Customized Profile. Rename it to whatever you prefer. In this profile you can select your ring tone, message tone, volume, etc. I only had to do this once, and everything worked perfectly!
Don't worry. It could be that the sound drivers are not instaled. Simply download the drivers from support.dell.com by entering the service tag. The sound should be back. The battery has nothing to do with sound. From the same website, install the BIOS update. That shoule get the battery message go away. Incase that does not happen, then you may have to buy a battery. The batteries have 1 year of warranty from the date of invoice.
I work in DELL, so please try what I ahve mentioned and you should be happy!!! If not, post a message.
what do you mean changes spkr what does that mean
