SOURCE: Casio FX-115 ES: SIN,COS,TAN (answer isnt correct)
It may be due to the angle unit used. You can have angles in
degrees, in radians, and in grads. You should set the default angle
unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The
values of angles calculated by the inverse trigonometric functions are
in the default unit that is set . This may be the source of the wrong
answers that you get.
Hope it helps.
Testimonial: "thanks alot!! "
SOURCE: how do i do a matrix problem in my casio fx 115
http://support.casio.com will allow you to download a manual
SOURCE: How do you switch between degree and radian mode
Press SHIFT MODE to access (SETUP)
Press 3:deg for degree OR
press 4:Rad for radian.
SOURCE: how do i get my
The calculator doesn't have those functions built-in. Use the relationships sec(x) = 1/cos(x), csc(x) = 1/sin(x), and cot(x) = 1/tan(x).
SOURCE: Where is my Degree Minutes
It's just above the ENG key, to the left of the hyp key, on the second column from the left.
