Ac not working,tried adding 134a ,but wouldnt take it inyo system.
There are 2 valves, a high and low. R134 should be charged on the high side (bigger fitting of the 2). If your system has no refrigerant in it then you may have a bigger problem than low freon like a leak.
When you charge it the air condition settings should be on high and running. This will help with the vacuum you need to charge it. There is a good chance the clutch is out on the a/c, if it the level is low it will make a clicking sound when engaged, if the level is too low it won't move at all. If this is the case you will need to add oil as well as refrigerant (this comes as a mixture, read the label on the can and it will tell you if it has oil in it).
After turning on the car, run the a/c on high, use the correct fitting and try adding the freon again, if it still won't take it then you'll have to get it serviced, most likely the air compressor is out.
