SOURCE: wiring ceiling fan to a light/fan dimmer swich
I think you should get a licensed electrician , if you dont wire it up correctly you could burn your house down and i dont think insurance companys take klndly to diy electrical work around the home .
SOURCE: touch dimmer malfunction
sounds like a loose connection to me, check to make sure all connections are tight. sometimes the bulbs themselves don't make a good connection in there socket.
u will have to take the switches out of the wall box and make sure the wires are tight, whether they are on screws or wires connected to wires. if it is wires to wires u may have to take that apart to make sure u don't have a bad connection there.
if it is none of that, then it is time to replace the switches
SOURCE: I have a leviton dimmer
One black is will hook up to one of the black wires inside the switch box in the wall and the other will hook to the other black wire in the box, The green will connect to the bare copper wire which is the ground wire.
