Dear
would you be so kind to let me know how I can repair the F18 fault. I don't have the manual anymore but I believe it is due to a drainage problem and I might just need to clean the filter.
Many thanks
Marco
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
Hello, F18 means pump is blocked or broken, clean filter first, no result change then you have to cahnge the pump.
Greeting Frank
Bosh washer will not adgutare or spin
Dear Frank
thank you for your feedback, but how do I clean the pump? do you have a link to some online manual?
Best Regards
Marco
