i have tried all the settings for so that i could plug the problem, but is of no use. i have tried all the settings for so that i could plug the problem, but is of no use.
You can't post conmments that contain an email address.
I have not used this model phone before, however, there are a few universal things you can check for alarms in general:
Have you verified that the tone used for the alarm is something you can hear?
Have you tested by setting the alarm to sound say 2 minutes from now?
Is there no system sound setting that is turned down too much?
Is your phone region/timezone set correctly? Some users of this phone have reported that the alarm rings at the wrong time & it was determined to be due to the timezone.
Good morning to you Ijust know onething about setting alarms and that is. To do it in the right order. When I set mine (nokia)firstly I find software in software there is a clock. New alert- alerts- world clock I click on new alert then on the screen fill in what is asked. I can also do this trough the calender- check if this works for you.. also check if alarm sound is on if not put it on. all the best Kolbrun
Erase all incoming and outgoing text messages from the phone. Then take out the battery while the phone is on. This problem tends to happen when there are more than 2000 messages in the phone.
sounds like a short or a setting peoblem.try to set it and if that doesnt work take it to where you bought it they will look at it for you for nothing.i encountered this before.my problem was a short.
The Alarm overides the Profiles. If you don't want an alarm to sound, don't set it. There is no point in setting an alarm if you don't want it to ring. Set the Alarm warning tone! to Vibrate.
there is problem in the circuit of ur phone. the track of ringer may be damaged better u take it technician so can be checked properly, 99% problem will be with tracks. tracks is opened. take it to technician
