Hello there and thank you for choosing fixya
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Check
to see whether there's power getting to the dryer. Is it plugged in? If
you plug something else into the outlet, does it work? If not, check
for a blown fuse or tripped circuit breaker.
Door switch
If
the door switch or the door-switch actuator is defective, the dryer
won't work and you need to replace the failed component. The switch is
inside the dryer main housing near the door frame. Sometimes you need to
raise or open the top or front of the dryer to reach the switch. To
determine if the door switch has failed, watch the part testing video at the bottom of this page.
Thermal fuse
On
many dryers, there's a thermal fuse (a heat-sensitive fuse that blows
if the dryer overheats) mounted to the exhaust duct inside the back
cover panel. The fuse is about an inch long. It's usually embedded in
black resin and mounted in a white plastic housing.
If the
fuse has blown, it has no continuity. When this happens, your dryer
either just stops heating, or it doesn't work at all. Be sure to
inspect the venting/heating system before replacing the fuse to put the
dryer back into operation. (You can't re-set this type of fuse.) To
determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring
Often
the main wiring connection from the house, at the dryer, burns and the
connection breaks. In this has happened to your dryer, you need to
replace the power cord and the terminal block that it is attached too
Testimonial: "Helpful solutions unfortunately they did not work for me. but thanks anyway for a quick response"
welcometo:http://www.fullmalls.com
The website wholesale for many kinds of fashion shoes, like the nike,jordan,prada,****, also including the jeans,shirts,bags,hat and the decorations. All the products are free shipping, and the the price is competitive, and also can accept the paypal payment.,after the payment, can ship within short time.
free shippingcompetitive priceany size availableaccept the paypal
=====http://www.fullmalls.com =====
jordan shoes $32nike shox $32Christan Audigier bikini $23
Ed Hardy Bikini $23Smful short_t-shirt_woman $15ed hardy short_tank_woman $16Sandal $32christian loubo utin $80
Sunglass $15
COACH_Necklace $27handbag $33AF tank woman
$17puma slipper woman $30
