Question about Necchi 3102 Mechanical Sewing Machine
Hi, my question how to put the thread on corectly. thank you.
  • Necchi Master
  • 7,365 Answers
Try sewusa.com
Posted on Aug 03, 2011
SOURCE:
The timing is definetly out, I sew for many years is not the needle or thread
It needs a professional service center repairman to review the action of this machine. Do not try an mess with it yourself as you could do more harm to the system that what has already been done.
Feb 03, 2015 | Sewing Machines
I have manual. Threaded correctly. Changed needle. Won't stitch.
Could be any one of these .-
1) check needle is in right direction.
2) if needle in right direction, check that the crochet hits the needle at the right spot.
3) check the tension on thread.
4)check bobin is corectly threaded .
Sep 01, 2014 | Sewing Machines
Sews 1/4" and then sews in place
1) remove upper and bottom threads. Try sew without threads.
Is fabric transported corectly?
NO:
- Drop feed dog button is OFF
- Dust under stitch plate
- Transporter malfunction (must be taken for a service to the BERNINA dealer)
YES:
- Upper or bottom thread jammed
- The upper thread tension is too tight.
- Wrong needle used (probably small ...)
Nov 20, 2013 | Bernina Bernette Deco 600
Singer5050 sews a little then jams top thread in pieces in bobbin area
Start from the begining.
Use your Instruction Book and make sure the machine is threaded correctly.
Put in a new needle.
Adjust the top tension to about halfway.
Fit a fresh wound bobbin that does not have all sorts of different threads still wound on it(a bad habit with a lot of people).
Make sure the bottom tension is correct.
Make sure the bobbin is fitted corectly.
Set the machine to do basic straight stitch(mid range stitch length).
Try sewing and see if the problem is solved.
Apr 19, 2012 | Singer 8280 Mechanical Sewing Machine
My thread keeps bunching up on the bottom side. HOw do I solve this.
Is the bobbin installed corectly? Try taking it out and installing it where the bobbin rotates counter clockwise. Make sure that the thread is not of a weight that that your machine is not rated for (apohlstery thread does not work well on some machines). Make sure that it is slid through all of the proper notches and use the wheel to have the needle pull it up before beginning to sew. If this doesn't work refer to a manual for that brand.
Jan 30, 2011 | Kenmore Sewing Machines
Thread keeps breaking and i can't get the stitch setting to go from stretch stitches to normal stitching
Be sure to check that the machine is threaded properly into the needle. Also look at the instruction book to be sure you have the bobbin inserted corectly and that the thread is place properly (threaded correctly) in the bobbin area. Some machines have a diagram on the machine, but if you do not sew frequently; it's easy to mis-thread the bobbin. Did your bobbin thread wind properly onto the bobbin (not loose or loopy). That too, can be a problem. Best of luck. Susan
Aug 04, 2009 | Kenmore 756A-30BH Mechanical Sewing...
Corect threading needle for sewing on brother lx3125
please follow the instruction
1. raise needle to its hieghest position
2. remove hand hole cover plate
3. remove bobbin case from shuttle, pull open latch of bobbin case
4. pull bobbin case straight out of shuttle
5 insert bobbin into bobbin case making sure thread is coming from bobbin.
6. pull thread through slot
7. pull thread under tension spring
8. holding latch open position case into shuttle, and release latch. case should lock into place when latch is released
happy sewing.
regards please rated me.. thanks
Mar 31, 2009 | Brother Sewing Machines
White 2037 Bobbin Filling
turn your thread 3 turns to the right, clockwise,
then pass theend of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Jun 14, 2008 | Sewing Machines
Thread tension dial
Hi , the two washer are assemble the curve should be back each other , first put a piece of thin tosser like a small nail put spacer can struck the tosser ,put washer back to back cone retainer next spring next cover with number indicating tensioner of thread next the knob.Put the tread between two cuve for enough tension.
Feb 22, 2008 | Euro-Pro Dressmaker 998B
Necchi 3102 Mechanical Sewing Machine Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
