I'm sorry that the codes are not working with the Remote to control Onkyo Receiver. The exact codes are 0135, 0842. Please follow the below steps and use these two codes again and check if that helps.
If the above codes are not working, please try the following codes and check if that helps.
0531
1023
1027
0074
0189
0531
Thanks for understanding. Please let me know the result.
In that case, please include one more 0 before all the above codes when programming the remote.
I have researched thoroughly and seems that the code should work with the device. Please add instead of 0 in the beginning and check the operation.
I'm really sorry that the previous steps didn't resolve the issue. Since the codes available for the Remote is only allowing you to turn ON and Turn OFF separately, the remote may not be compatible with the Onkyo Receiver.
You may have to purchase an Universal Remote to resolve the issue. Thanks for understanding.
Yes, unfortunately, the next available option is to purchase an Universal Remote.
The Comcast remote requires a FIVE digit code: it will not accept a four digit code.
The remote would not accept any of the codes with a zero in front of them. I even tried a 3 in front of them since the remote instructions indicate that the five digit codes starting with a 3 are for audio devices.
If I input all the four-digit codes you gave me with a "0" in front of them, the Comcast/Infinity three-device remote does not accept them: I get a single long flash instead of two short flashes. If I input all the four-digit codes you gave me with a "3" in front of them, the remote accepts them (get two short flashes). However, the last six codes you gave me with "3" in front do not work (0531 1023 1027 0074 0189 0531; note last one repeated); 30135 only turns on the Onkyo receiver (will not turn it off), and 30842 only turns off the receiver (will not turn it on) --- as I said in my initial note. Unless you have another solution, I will need to check with someone else or go out and buy an universal remote.
Thank you for your time: I think my only option now is an universal remote.
