2007 Harley Davidson FLHX Street Glide Logo
Posted on Jul 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a Bosch undercounter freezer and it won't stop beeping!!! All the lights flash whilst beeping, the lights are under the super freeze button, mute button and the temperatures. If I hold down the far right button the beeping stops for around 5 mins and then just starts again!!!
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Jul 31, 2011
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567513
Points
3788
The beeping is a signal that the fridge has not got down to, or holding temperature... You may have a thermostat or gas system fault. Check and see that the fridge has actually got cold.
Why does super cool and super freeze orange lights flash
A blinking orange light on appliances such as refrigerators and freezers indicates that the "supercool" or "superfreeze" feature is active. These features are designed to quickly cool or freeze the contents inside the device. A flashing light serves as a visual cue that the unit is actively working to quickly cool or freeze food. Once the desired temperature is reached, the light will stop flashing, indicating the unit has completed the cooling or freezing process.
My Hotpoint FUFL1810P that keeps beeping and the lights inside are flashing when the door is opened, I have reset by turning the power off and on again and also by turning the freezer switch off and on....
Something to think about from the manual for your freezer. Also I would check the temperature of your freezer with a thermometer to make sure it is freezing ok .Troubleshooting
If the appliance does not work, before calling for Assistance (see
Assistance), check for a solution from the following list.
The green POWER indicator light does not illuminate.
• The plug has not been inserted into the electrical socket, or not
far enough to make contact, or there is no power in the house.
The motor does not start.
• The appliance comes with a motor protection control (
see Start-
up and use
The indicator lights are on but the light is dim.
• Pull out and reverse the plug before putting it back in the socket.
a) The alarm sounds.
a) The refrigerator door has remained open for more than two
minutes (the buzzer will stop sounding when you shut the door) or
the correct switching-off procedure was not followed (
see
Maintenance
b) The alarm sounds and the two yellow indicator lights
flash.
b) The temperature in the freezer is too high. Check the quality of
the food products and dispose if necessary.
+ buzzer =
Heating is excessive
c) The alarm sounds and the two yellow indicator lights
as well as the green one flash.
c) The temperature in the freezer has reached a dangerous level.
The food must be disposed immediately.
+ buzzer =
Heating danger
b/c)
In both these cases the freezer will maintain a temperature of
about 0°C so that the food does not re-freeze.
To turn off the acoustic signal open and close the refrigerator door.
To restore normal operation bring the FREEZER OPERATION knob
setting to
(off) and turn the appliance on again.
The green POWER indicator light flashes.
• The appliance is not operating correctly. Contact the Technical
Assistance Centre.
The refrigerator and the freezer do not cool well.
• The doors do not close properly or the seals are damaged.
• The doors are opened too frequently.
• The OPERATION knobs are not on the correct setting (
see
Description
• The refrigerator or the freezer have been over-filled.
The food inside the refrigerator is beginning to freeze.
• The REFRIGERATOR OPERATION knob is not on the correct
setting (
see Description
• The food is in contact with the back inside wall of the refrigerator.
The motor runs continuously.
• The SUPER FREEZE button has been pressed (rapid freezing):
the yellow SUPER FREEZE light is on or flashing (
see
Description
• The door is not closed properly or is continuously opened.
• The outside ambient temperature is very high.
Freezer door left slightly a jar overnight two lights inside flashing super cool and super freez how do I stop them flashing appliance seems to be working
I now have these kinds of refrigerators and freezers to maintain, and have found some will take as much as 18 - 24 hours before the lights will shut off after they have overheated from their doors being left open.
God bless your day.
1helpful
Hotpoint FZFM171 freezer door left open all night, has defrosted and the 'super freeze' light and alarm light wont stop flashing. How do we fix it?
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
Constant flashing lights
These lights flashing are an indicator that something is wrong with the unit. Once the problem is solved the following steps will reset the lights so that they stop flashing. If you don't believe there is an issue you can try these steps and it will reset if nothing is wrong.
1.) Turn the refrigerator and freezer to 0 this will cause them to turn off.
2.) Hold Super Freeze and Super Cool buttons down for 15 seconds.
3.) Return your freezer and refrigerator temperature settings back to what they were before you turned them all the way down.
If this doesn't stop the lights something is still wrong with your unit and it is informing you of this.
I hope this helps!
Help, i turned by Bosch Logixx GSL 14424 GB freezer off to defrost and it now won't turn on...
Turn it round and check the electrics for the compressor are dry. You probably flooded them when defrosting and may have shorted something. If it still won't start with everything dried out, call a fridge technician
May 02, 2012 • Freezers
2answers
The alarm button is flashing
-18c is about 0 F. it shold be cold enough to freeze you know what.
you might want to turn the tempture up a little.
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
