Cars & Trucks Logo
Posted on Jul 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whats the part number for a 95 camry timing belt is it 94167 (163stp8m267) thanks for ya assitance
Vincent G
Level 3:
  • Toyota Master 2,363 Answers
  • Posted on Jul 31, 2011
Vincent G
Toyota Master
Level 3:
Answers
2363
Questions
Helped
1032818
Points
5917
3.0 Liter V6 engine use Dayco 95257
2.2 Liter 4 cyc engine use Dayco 95199
======== 94167 is an old Deyco Euro part #
It will fit the following
Toyota Camry 2.0 i 1996 3S-FE Petrol 10/86-06/91
Toyota Camry 2.0 i 16V 1998 3S-FE Petrol 10/86-06/91
Toyota Camry 2.2 i 16V 2164 5S-FE Petrol 06/91-07/01
Toyota Carina E 2.0 i 16V 1998 3S-FE Petrol 02/92-10/97
1helpful
2answers
Where is crank position sensor on a 1994 toyota 2.2liter 4cyl ?
Where is the crank position sensor on a 95 Toyota celica gt 2.2
search.aibing.cc/Where+is+the+crank+position+sensor+on+a+95+Toyota...
P1335, No Crankshaft Position Sensor Signal - Engine Running. ... 91 1991 ToyotaCelica GTS Engine Mount Right 2.2L 4 Cyl Genuine. ... 1990, 1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001 . ... Powered by a 2.2-liter engine, the Celica now had ST and GT trim models. ... in 1986 and a 2.0-liter ...
Where is crank position sensor on a 1994 toyota 2.2liter 4cyl ...
www.fixya.com/cars/t26080657-crank_position_sensor_1994_toyota
31 mins ago - It is not behind pully nor in dist all videos show - Toyota Cars & Trucks question. ... Change a crankshaft position sensor on a 2000 eclipse.
toyota camry crankshaft sensor - ABMforum.com
abmforum.com/toyota-camry-crankshaft-sensor.html
toyota camry crankshaft sensor 99 camry crankshaftcamshaft position codes i got a problem with my 97 ... The car 96 toyota camry 2.2 liter 4 cyl. ... 1994 toyota camry 2.2L 257k miles Symptoms Car overheats Top radiator hose hot bottom cold ...
Toyota Camry 5SFE Engine Timing Belt, Water Pump and ...
hubpages.com > Autos > Do It Yourself Auto Repair
Jul 10, 2014 - The Toyota 5SFE motor is a four-cylinder, 2.2 liter, timing-belt-driven, double ..... Remove the lower timing belt cover with the crankshaft position sensor. ..... I've never, ever replaced the harmonic balancer on a 4cyl 5SFE.
1995 Toyota Camry LE 4 cylinder - YouTube
? 2:27
https://www.youtube.com/watch?v=7TW6hlUiHWQ
Sep 6, 2011 - Uploaded by jacasan2000
Am2 fuse blown,no dash lights a pair when i turn ignition key except engine oil light.when i replaced am2 fuse it blew straight away after briefly flashing up the engine light.
Serpentine belt diagram for 2004 camry le 4.2 liter automatic trans front wheel drive , just needbelt routing diagram please! , allready have the belt , know how to instal belt just need diagram thanks
Here is the link for ya! copy and paste in your browser good luck! http://www.autozone.com/autozone/repairinfo/specifications/specificationsMain.jsp?childCatName=Belt+Routing+Diagram&childCatId=25300467&categoryNValue=25399999&categoryNameForTitle=External+Engine&categoryName=EXTERNAL+ENGINE&childCategoryNameForTitle=Belt+Routing+Diagram#
7helpful
2answers
Timing Belt Diagram All About Timing Belt Diagram for a toyota camry 1994
Click on the following direct Link. It has the Timing Belt Diagrams with Marks for the Camshaft and Crankshaft that you will need.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1994/make/toyota/model/camry/1994_toyota_camry_timing_belt_diagram_marks.htm
1helpful
95 TOYOTA CAMRY WONT CRANK
If it cranks immediately and then dies .your distributor may need to be replaced. If you have to whirl it over several times before it starts the timing is off
1helpful
95 Camry was running great. Driving down street car bucked once and died. Cranks but will not start.
check your timing belt; it is probably broken; then: re-time the camshaft pulley with the crankshaft pulley (line up the marks on the new belt) and, install a new one
2helpful
2answers
Timeing belt broke running cant seem to get it back in time
It may be one tooth off. That all it takes. One tooth on the belt of the crank or cam. The computer gets it's spark pulse from a sensor on the crankshaft. If it gets the pulse a fraction of a second to late or too early it won't time correctly. Check it out one more time. Hope this helps. Good luck and thanks for using FIX-YA.
5helpful
2answers
Diagram for firing order for a 1991 toyota camry
Here ya go:
1991 Camry Sedan 2WD
2.5 liter DOHC V-6 (2VZ-FE)
1994 Camry quit running. Died while driving on bumpy gravel road.
Have ya checked the timing belt to see if it has stripped teeth or broken? Thats a common problem on those seein how ppl dont even heed warnings on the timing belt .. check it and let me know.. Thanks.. get back to me
10helpful
Timing belt 2005 4 cylinder camry
Hello, A 2005 Camry with a 2.4 4 cylinder engine has a timing CHAIN not belt. I don't think that there is a routine maintenance schedule for this. If there is no audible noise coming from the chain area, you probably have nothing to worry about.
I hope this helps
CYA, Gator241
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
