no it's not your battery it is in the screen itself , the motorization is broken or damaged . You will need to get that repaired by either taking it to a repair shop in your local area that services jensen products or send it back to the company. If you choose to send it back to the company you will need to contact them first to get a return authorization number . Audiovox/jensen 1-800-645-4994
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at [email protected].
Heres the best way to fix;
Quote from manual
"Programmable Turn-On Volume (Pg.12)
This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting."
Ah i had the same problem. I turned to the manual and it worked for me :)
Good Luck,
Ern
