Casio FX-9750GPlus Calculator Logo
Posted on Jul 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Am trying to calculate corelation on a Casio fx-9750GII,
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Aug 01, 2011
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4671733
Points
21595
Press Menu.
Use arrows to highlight STAT icon and press EXE.
Enter your data in two lists (x-values in L1, Y-values in L2)
Press F2 to activate the CALC Tab at the bottom of screen.
This is what you see.
Press F3 to activate the REGression tab.
This is what you will see: the TABs at the bottom of screen.
Each tab corresponds to a regression moam trying to calculate corelation on a Casio - 8_1_2011_10_38_52_am.jpgtic, etc.
8_1_201am trying to calculate corelation on a Casio - 8_1_2011_10_36_07_am.jpg=
If you press F3:X^2, you get the following
You see the parameters of the regression equation, the coefficient of determination r^2, and the Mean Square error. No correlation coefficient is defined for this regression model.
For other models like linear, logarithmic, power and exponential am trying to calculate corelation on a Casio - 8_1_2011_10_44_16_am.jpgation coefficient is defined and is thus displayed with the regression equation. It is the r-value.
Casio fx-9750GII is giving the wrong answer, is it broken?
Check the calculator with a simple 2X2 matrix that you can invert by hand easily and see if it gives you the wrong inverse for it. It is also possible that YOU made the mistake.
1helpful
Hoe to Calculate nPr and nCr on a Casio fx-9750GII?
In Run/Mat screen, press the OPTN key followed by F6, the F3:Prob. The nPr and nCr tab are accessible. Type n then the relevant tab, followed by the r-number.
How to derive function using fx-9750GII
Is it possible to change d/dx into d/dy on a Casio fx-9750GII? If so, how?
4helpful
Where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It depends on what MATH you intend to do. Put the calculator in Run/Mat screen then press the OPTN key. You will see several tabs. Press the function key under a TAB and explore what is offered. Go through all the keys (F6 also) and see what the new tabs do.
In general it is most helpful to read the manual that shipped with the calculator.
2answers
How can i Make a Casio fx-9750gII simplify radicals?
I am sorry, but the Casio FX-9750GII does not manipulate radicals (roots). Maybe you mean fractions?
11helpful
I have a Casio fx-9750GII, how do i switch my radians to degress?
From the Run Mode (select it and press exe), enter Setup (Shift Menu) and then highlight Angle. Press the function key that correponds to Deg and then press Exit.
The manual for the Casio Fx-9750GII is here: http://support.casio.com/manualfile.php?rgn=1&cid=004002013 . Other calculator manuals are here: http://support.casio.com/manuallist.php?rgn=1&cid=004 .
I hope this helps.
8helpful
How do I calculate normal distribution using a fx-9750gII?
I don't know about fx-9750gII, but for fx-991MS
Change the mode to REG
Then
Shift->3(DISTR)->1(P())->give your Z value
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
