After i put clothes in the cabrio washer and turn it on, a little bit of water dispenses, then the washer spins. then it would stop after about 20 seconds, then dispense a little more water, then spins again. the tub never fills up at all..
oL is an Overload error. Try running a cycle empty.
If oL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent. Close lid and press START/PAUSE.
Probably the worst washing machine manual I have ever read!
Try this.
Put your wollens in the machine, set for cold water, Woollens Cycle and your 'Soak' detergent. It will agitate a bit, and as soon as it stops filling, turn it off.
After say 20 minutes. Then Move the dial to Spin, and pull the knob out. It _should_ pump out and spin.
Your pump is most likely in need of change. They are $90 on Sears website do it yourself not that hard. Its a plastic housing with a cpl rubber connections under the washer. Set the washer on its face the pump located on the left bottom.
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
The washer is unbalanced, make sure it is level and the clothes are distributed even, if this have been check. put the unit on cold water and see how fast it comes in. Safety programmed into the unit if it takes longer then 10 minutes to fill it will just drain. This is to keep the washer from flooding out. Check the water inlet where the hose screws on, it could be plugged up with grit
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
pull the dispenser of turn it up side down now move green clip around dispenser down..take a little screw driver and remove all that wax build up...turn dispeser right side up and let hot water hot as possiable..now you should be find...if not add a little bleach with the hot water rinse out..if your getting fabric softner around tub ring ,,its to thick,,instead of dripping down its flying up...fill dispenser to top with water than add fabricsoftner ..it will even it self ,,water first...
