Question about MTX SUB1 Subwoofer
It sounds like my mtx sub1 650 needs a new amp, where do i get it at ??
Checkout ebay search for amp plates
Posted on Aug 05, 2011
SOURCE:
I just recently bought a brand new MTX magnum amp and dual 10" enclosed subs deal off of amazon. They arrived today, and with the help of a friend who is good with car audio systems, we set the whole
the best thing to do is get in touch with amazon,and see what they can do about it,if you try to fix the problem yourself it will invalidate the garantee!
Dec 05, 2012 | MTX Car Audio & Video
How much oil is needed in my honda mtx 125 forks
you need to consult your manual for type & grade NOTE: DO NOT MIX old&new oils make sure you have the correct amounts & grades also be sure bike is level & drained clean
Aug 15, 2012 | Honda Motorcycles
I have 4 mtx 9500 12in subs 2 of them is on a mtx 92001 and the other is on a mtx 4001d . would it be better to run all four on the mtx 4001d. for more power and a better sound or how should i run this set...
NEVER mix different power amps. Depending on the ohms of your subs, sell one of the amps, up to you. The 4001 has more power, but either amp will do the job, the amp needs to see a 1 ohm load, so your subs have to be dual 2 ohms, or single 4 ohms to do this. If your subs are dual 4 ohms then you will have to run your amp at 2 ohms which would be have the power, or a half an ohm, (Not Recomended) and be at double the power. You may be able to do a competion sound off and just "Burp" the subs, but at a half an ohm, dont expect to listen to it to long before it goes into protect and shuts down.
Sep 06, 2011 | MTX Thunder Elite TE4001D Car Amp
What kind of sub would go good with my amp the MTX 4105 d amp
you can try the new soundstream T5 or a MTX 9500 but the T5 would sound deeper and cleaner
Aug 04, 2010 | MTX Thunder 4250D Car Audio Amplifier
I have a MTX 4105D amp and it cuts in and out what could it be
could be not enough voltage or the settings on the amp are not correct for the sub you have its a feature that MTX put on thier new amps
I have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Feb 28, 2010 | MTX Car Audio & Video
Mtx TC-6001 Amps Problem
I had same problem with a TC6001 and get solution from MTX, not send to MTX instead MTX kindly sent a quotation for parts to be replaced, I can tell you what parts need to be replaced if you still need a solution.
Jul 12, 2008 | MTX 6001 Car Audio Amplifier
MTX 4501 Mono Amp - no output
It sounds like you have a defective switch or a broken solder connection. If the amp is new, return it for repair/replacement. Don't break the warranty seal if it has a warranty.
Apr 03, 2008 | Car Audio & Video
Mtx ta7801 amp not working
Depending on where you live, Car Tunes is a good place to fix it but it might cost a good amount. I have a mtx 1501XD and the same problem, lights but no sound i saw no marks inside mine however. They told me i was better off buying a new one bc it was going to cost so much to fix most likely. That was coming from a guy I know so they were just trying to **** money out of me either, he does sound for a living.
Feb 25, 2008 | MTX Thunder 8302 Car Audio Amplifier
Need info
how much power "wattage" does your speakers have and mtx is too powerful right? so need a good quality speakers. reply me with the wattage of the amp and the speakers.
Jan 15, 2008 | MTX 3002 Car Audio Amplifier
MTX SUB1 Subwoofer Logo
120 people viewed this question
Top MTX Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a MTX Audio Player and Recorder Expert? Answer questions, earn points and help others
