I think some confusion here, The model indicated is a WS series set does not use a lamp but has three picture tubes and the power light should be green on this model (ie no lamp light).
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Good Day, cantseewhat;
It sounds like your TV has a problem. It could be and most likely be CRT Coolant on the circuit boards. If you handy, then clean PCB's with acetone on areas which fluid appear. If not handy call aN Authorized Sevice Center and have them give you a written estimate B4 repairs. Cost $450.00 to 650.00 depending on your location. Good Luck, big IRISH.
