Car Audio & Video Logo
Posted on Jul 30, 2011
Omega bass tube wire diagram - Car Audio & Video
Juan Ramirez
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 18, 2015
Juan Ramirez
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1091
Points
I lost the conector for omega sub bazooka how i can find replacemnet
Wiring instructions dean edge bass guitar 4 pots & battery
To wire a Dean Edge bass guitar with four pots (potentiometers) and a battery, you will need to follow the wiring diagram for the specific model of your bass guitar. Here is a general overview of the wiring process:
  1. Start by connecting the ground wires to the pots and the battery. The ground wires should be connected to the ground terminal on each pot and the negative terminal on the battery.
  2. Next, connect the power wires to the pots and the battery. The power wires should be connected to the positive terminal on the battery and to the power terminal on each pot.
  3. Connect the pickup wires to the pots and the output jack. The pickup wires should be connected to the pickup terminals on the pots and to the input terminals on the output jack.
  4. Connect the control wires to the pots and the output jack. The control wires should be connected to the control terminals on the pots and to the output terminals on the output jack.
  5. Test the wiring to make sure everything is working properly. If there are any issues with the wiring, you may need to double-check your connections or consult the wiring diagram for your specific bass guitar model.
It is recommended that you follow the wiring diagram provided by Dean or consult a qualified technician if you are not comfortable wiring the bass guitar yourself. Improper wiring can damage the guitar and potentially pose a safety hazard.
Dec 12, 2022 • Bass Music
Bought a used vehicle with remote start. Cant get it too work on purpose. Has started on accident twice. Omega part 152-03 is remote. Excalibur alarm and remote start. Please help
Most likely the installer did a horrible job of installation, poor connection are common, many time the wires are just twisted together when they should be soldered and shrink tube insulated. I would check all wiring that was installed.
1995 Cajun bass boat. Where can I get a wiring diagram?
cajun manual and parts manufactures
www.bbcboards.net > BBC Boards > Bass Boat Forums > Cajun Boats
Jul 18, 2011 - 13 posts - ‎11 authors
... for cajun boats and also a complete manual in pdf format and wiring schematics. ...bassmannbama is offline ... a wiring diagram too because switches arent working andmy wiring ... My email is : [email protected].
Cajun Boats Owner's Manual 1992+ available on pdf
Apr 19, 2012 - 4 posts - ‎4 authors
I scanned in my owner's manual and have it available if anyone is ... Mine is a '95 1950 Fish n Ski, but I believe it would cover bass boats as well. ... Looks like I'll need to learn about electrical and general boat repair.
Nov 19, 2015 • Boating
Pickup wiring diagrams
https://www.talkbass.com/threads/p-bass-wiring-diagram-please-help.1208915/
Wiring burns bass vista sonic
Could you please be more specific? I'm not sure if you're looking for a wiring diagram (if so, I have one posted below), or if you're having a problem with grounding or other wiring issues.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=passive_soapbar
The above link is a wiring diagram for bass guitars that closely match the one you are asking about.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
1helpful
How do I install omega tube subwoofer
This is not a car subwoofer, a professional musicians speaker, most car amps will destroy this within a week or two due to their very poor distortion levels.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
