MTX JackHammer JH1200 Car Amp Logo
Posted on Feb 28, 2018
My jh1200 2400watts sounds great with the car off but when i start the car it jumps in an out everytime the bass hit it goes to protect an iv tried several differant radios, iv changed rca jacks everthing battery wire remote wire speakers is this a comon problem with this amp
5 Related Answers
A
Anonymous
  • Posted on Aug 12, 2007
SOURCE: feedback/maxing out speakers.....
its connected directly to the head unit
Anonymous
  • 67 Answers
  • Posted on Sep 19, 2007
SOURCE: Audiobahn A 18001DT
the remote of amp. is not a ground it is a pos.+ 12 vlts look the back of your car stereo red the remote and conect to remote of the amp. if no sign remote of the car stereo conect to the 12 vlts of your bat.
Anonymous
  • 631 Answers
  • Posted on Sep 30, 2008
SOURCE: THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Anonymous
  • Posted on Jan 03, 2009
SOURCE: my mtx thunder 1501d car amp making noise in the subwoofers
This is common with pioneer head units, the rca jacks are not properly grounded and this lets engine noise come through the rcs cables. This thread explains a fix http://www.caraudio.com/forum/showthread.php?t=337644.
Anonymous
  • 655 Answers
  • Posted on Jun 03, 2009
SOURCE: i have a mtx thunder 1501d..i have the power cord
Hello tonytone54, The ground should go directly to the vehicle frame, never through a cap, fuse, or anything else. Also, if you are connecting positive through a cap, make sure that you charge the cap before connecting it. Hope this helps.
Hey I have a rockford fosgate t2500bdcp-1 when ever the bass is about to hit the amp goes to protect mode and comes back on
If you can tell that it is about to hit and the amp goes into protect mode, the amp is being over driven on the input.
Jbl a3001 goes into protect mode when bass hits. Wrkd then just stopped. Amazon replaced the amp with a new one, new wire, loc, rca, grnd locatn. No dice. Ideas?
Bad or shorted voice coil on sub maybe. If you have two subs try them one at a time to see if it goes into protect mode. Whatever sub does it is bad.
1helpful
2answers
So i have installed my amp, epicenter, all wiring is done, hace great ground.. But once i turn my car on to sound check everything starts fine but after turning up the volume a bit.. My amo goes into...
It sounds like you have your gain to high. best way to solve this is by turning the gain way down to - or lowest number , then turn everything on and upto the volume you desire, then slowly up the gain. also avoid using bass boost, I agree it sounds great but it puts strain on the amp and shortens life in the amp. with the bass boost off, you can adjust others (not the gain) to get bass.
Hope this helps
What would cause my fossgate t1500 to shut off everytime the bass hits hard I have two t12s that it pushes
Sounds like your amp isnt powerful enough to power your subs, whats the wattage of your amp and both subs? Its shutting off when hard bass hits to protect itself from blowing, a good feature as a blown amp means a new one. an amp should always be more powerful than the speakers / subs you are connecting to it. for 2 500w subs your looking at a 1200w amp minimum.
My infinity reference 7540a amp cuts in and out with heavy bass when the ''loud'' feature is on. I redid my ground, remote wire, shortened my power cable, and double checked all speaker connections. I dont...
sounds like ur gains are set to high and is going into protect mode
also what ive seen happen before is the speakers (if mounted in metal shelf or door and arnt bolted down correctly can flex under bass notes and flex the speaker that much the termanls short onto the metal and amp hits protect mode
(rare but worth a look if you think u have elimanted most other things Had a dude come to me when i was working in sydney with this problem )
also could be things like clipping protection , overheat protection ,amp drawing to much current from the alternator
do your lights dim when you hit the bass notes ?
get back to me and im sure we could solve this problem
I have a sony 100 watt amp and it wont stay on for very long
You need more current.Bass notes require more juice and the best way to get more power for bass is to add a power capacitor to your system . They are easy to install and you can get one for less than a hundred dollars that should be enough for your amp and subs.
Gain conrol problems
relatively simple 2 leg pot. fix.
Under $50 to repair.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
1helpful
2answers
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Top MTX Car Audio & Video Experts
Jose Ramirez
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
