Hello &
Welcome to FixYa E13 error in
your Bosch WFMC washer is a drain error and is displayed when the drain time
exceeds & the washer is unable to drain so the door won't open sometimes
when this error is displayed. You will have to clean the drain trap in the
bottom right hand corner. You can stick a straighten paper clip in the access
panel located inside the front bottom panel through the whole and then turn the access
panel counter clockwise to unscrew the plastic drain cap behind it. After
everything is cleaned and the error returns then replacing the drain pump is
recommended repair. Please get back to me if you have any other questions. Kevin
Hello &
Welcome to FixYa
E13 error in
your Bosch WFVC washer is a drain error and is displayed when the drain time
Kevin
Hello &
Welcome to FixYa
E13 error in
your Bosch washer is a drain error and is displayed when the drain time
Kevin
