SOURCE: Kenmore air cleaner
I just bought the same model and also have the smell. My previous one did not so I returned the first unit and the second units smells the same. I called Sears Customer Support and they told me that it is probably due to the factory smoke test they do on each unit. He said let it run for a few days and it should dissapate. I went a step further and am trying a new filter and if this works he said call the store and they will get me a new filter.
SOURCE: I purchased a Hybrid GP germicidal Air Purifier,
Locate the photo electric eye that picks up the need to clean and give it a thorought cleaning. Good Luck and I hope you get it repaired. That photo cell should be your problem It's probably a little black or ruby red dot in a fin or on the housing where yhe air passes.
SOURCE: The Honeywell electronic air cleaner constantly
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal .Remove both the cell and check clean the bottom portion by using a vacuum cleaner attachment. If the snapping continues with the cells remove contact your contractor.
SOURCE: I have an F50f electronic air cleaner. none of the
you need to change the power supply please contact your heating and cooling contractor for service on the unit.
