One is earth for the right, one is earth for the left, one is right channel and the other is left.
You don't need to know the colours to find the left and right channels. Just connect the turntable to the amp switch on. Then with your finger touch each wire one at a time. One will buzz on the left the other will buzz on the right. You might even get a slight buzz from the two earths.
The cartridge might have the left or right channels marked so you can connect them, but if it doesn't just connect the left to one side and the right to the other, then do the same with the earths. try it out, if the channels are the wrong way round change them, if the sound doesn't sound right change them again and again till it sounds right. You won't damage the amp or cartridge from doing this. Unless it's some kind of static effected cartridge!
