How to set up an Ozark Trail 11ft X 8ft Dining Canopy
It is best to have two people assemble this.
Rods:
4 Side Gables: 2, 2b
3 Rafters Across: 1, 1b. 1b
4 Legs: 1, 1B & 3B
The pieces were not labeled so I used a label maker and permanent marker to label the rods and connectors. The plastic connectors do label the legs and gables but don't label the rafters.
1.Connect a 2 and 2b rod to create a Side Gable. Repeat with the other three 2 and 2b rods.
2.Insert the four Side Gables into the two unmarked connectors (written with a G) to make the pitch of the roof.
3.Connect a 1 rod with two 1b rods to create a Rafter. Repeat to create two more rafters.
4.Insert two Rafters into the 4 corner connectors (written with an R) to form a rectangle frame.
5.Insert the last Rafter in the center connectors to support the peak of the roof.
6.Connect a 1 with two 1b rods to create a leg and repeat to complete the four legs.
7.Inset the legs into the four corner connectors (written with an L).
8.Place the canopy on the frame and use the Velcro tabs on each end to secure in place.
9.Place the hooks (attached to ropes hanging from D Rings) into the appropriate hole on the legs to keep it tight.
10.Stake the canopy to avoid it blowing away.
When assembling alone, put the leg segments into the plastic connectors; pull the canopy over the short frame, then walk around to add the additional leg pieces.
SOURCE: were can i get a tent manual for a ozark trail
Not sure if they have the exact manual you need but i found a manual for my ozark trail tent at www.ozarkt-trail-tents.com
SOURCE: how to put up a tent- ozark trails 16x12...
I have this tent and have successfully put it up a few times. It's a big tent but it's frustrating to put up sometimes. Plan on having several people to help you. I find that it greatly helps if there are a total of 3-4 of you.
The poles are color coded. The center support are red rods. The two side supports are blue with the graphite looking rod that goes through the tent.
Spread the tent out on the ground and try to square it up and make it even. Run the center pole through the top and connect to the curved pieces which then connect to red dot poles on the side. Hoist the whole thing up. Have two people hold those poles for a while.
Get the bue poles into the black couplings and put the graphite looking rod through the tent. It will be a little tight. Hoist the blue poles into position. The bottom of the blue dot poles should be about two feet from the center. They extend outwards at about a 30 degree angle. Keep your center people holding the center poles and let the two blue dot pole section extend outwards. You'll start to see a tent shape. Your center holder people may need to keep and eye on the poles.
Now, start trying to get some stakes in. Work the corners. Once those are in and things start getting tight, it should start to hold on its own. Work all the stakes in and make adjustments to all the poles as necessary.
Extend the red dot poles up until the roof is at the proper height. I tend to do this last.
The fly basic basically clips on into holes on the blue dot poles.
It's kind of a pain to set up but its a big tent and works well once it is up. Good luck.
I took a ton of pictures after I got it up the first time. As I took it down, I shot the pictures. Then, I reverse the order and printed them to a book and now sort of use that as my manual.
Have fun.
SOURCE: i lost my manual to
I will suggest you check manualnguide.com to search for the manual of your ozark trail 3 room xl vacation lodge as requested.
Take care.
SOURCE: I have a Ozark Trail tent and need instructions on
http://store.eurekatent.com/media/document/TUNDRALINE09IM.pdf
That should give you the instructions you need.
SOURCE: i lost the manual for
I just got mine on walmart.com under where you order there is a downloadable set of instructions.
