I bought this system over a year ago and now the rear speakers are not linking with the system. I tried the reset button but still have no luck. The system keep displaying "rear check". Please let me know if there is something else I could do or is there any warranty for this issue?
Thanks
Don
SOURCE: my main unit will not connect to the rear unit
I had a similar problem but mine cut out intermittently.
First, check to make sure the speakers are plugged in solidly. I was plugged into an outlet with a fancy cover and it caused the connection to short out intermittently.
2. Make sure all your wires are securely attached to the receiver unit.
3. If that doesn't work, try turning off the wirless speakers and the Home Theater system and then turn on both
of them.
If one of these doesn't work, Samsung has chat support available onlline.
Good Luck!
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
SOURCE: i keep getting the 'rear check' message on the
With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
Note: You can release the REMAIN button when the POWER LED blinks blue.
With the wireless module turned on, use a ball point pen to press the RESET button on the back of the wireless module. The POWER LED in the front of the home theater blinks two times.
Turn on the home theater. The LINK LED on the front of the SWA-3000 changes from red to blue, indicating the wireless module has connected to the home theater.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
SOURCE: swa3000
Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
My rear speakers stopped linking with the main unit about 2 years after we bought it, and the online troubleshooting doesn't help because we have the SWA-2000 wireless receiver, for which there are no troubleshooting instructions.
i cant get my rear speakers to work.i tried the reset button but it wont sync up.please help
i had bought a new surround sound system and i decided to keep the samsung but now i cant get the rear speakers to link up with the subwoofer what do i do
