SOURCE: Decalcification and Ventilate
Try to make a cup of water (tea), make sure you get a full cup of water. If you only get a half cup of water then i think you have to replace the flow meter in the machine.
Best regards
/Mirran
SOURCE: jura impressa s9
you need to clean / lubricate the "plungers". The normal clean cycle will strip off the lubricant over time. See my post here:
http://www.fixya.com/support/t348905-malfunction_8
SOURCE: Declcification Program not working
Call Capresso co. at 1-800-220-5701. I had a problem and I received excellent help, a step by step walk -through which got my machine back to service. Great machine! Great help!
SOURCE: Impressa S70 - Malfunction 3
This indicates that either the sensor for the thermoblock is defective or the thermofuse is blown. For this you need to go to your local dealer for service. I also recommend that you measure out the mains.
In worst case the powerprint or the mainboard sends wrong signals to the thermoblock so it`s overheated.
SOURCE: No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
