HTC Hero Smartphone Logo
Posted on Jul 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My phone will not turn on. It shows a symbol of a phone with a red exclamation point inside of a triangle.
Anonymous
Level 3:
  • Master 1,116 Answers
  • Posted on Jul 30, 2011
Anonymous
Master
Level 3:
Answers
1116
Questions
0
Helped
527709
Points
3536
You're in recovery, press vol up and power and you get a small menu where you can select to apply the clockwordmod update.zip to reset your battery stats (assuming you're rooted)
1helpful
Doro Flip Phone. I have a red triangle on text messages on my phone?
Question edited for clarity.
Question moved to a better category.
Hello Maurice
questions like this really need to model number of model name. Doro make lots of flip phones. There are various ideas here in the links below.
Remove battery to reset.
Your data usage is exceeded.
The text wasn't sent.
What does an exclamation mark in a red triangle next to a text ...
https://www.cellphones.ca > answers > what-does-it-mea...
Oct 9, 2014 - What does it mean when there is an exclamation mark in a red triangle next to a text message? It shows part of a text when I open it up none ...
Red Exclamation point...... - HTC Droid Incredible - Android ...
https://androidforums.com > ... > HTC Droid Incredible
May 4, 2010 - The red triangle with the exclamation mark is showing up because somewhere in the string of texts you've been sending to this person, you did ...
16 posts · It comes up when sending text messages. Not in the messaging widget, but when you actually ...
W\hat does it mean when i see a red exclamation - Fixya
https://www.fixya.com > Forum > Cell Phones
Nov 20, 2019 - Hello, Normally, the red spot on an envelope in the sent messages means that your text has not been delivered to the destination phone number the text was sent ...
1 answer · 3 votes: Hello, you don't have to be bothered my friend,the red exclamation sign simply indicates that the message is broken along the way which means the message ...
SOLVED: Hi, my husband has a Doro 508,a big red ...
1 answer
Sept 16, 2019
SOLVED: Red triangle appears when text message sent ...
1 answer
May 14, 2015
How do i get rid of red exclamation mark on text ...
1 answer
Aug 21, 2014
What's the red triangle symbol on the android - HTC ...
1 answer
Apr 7, 2011
More results from www.fixya.com
What does the red triangle mean beside my "sent message?
https://forums.androidcentral.com > ask-question > 590...
Oct 5, 2015 · 3 posts · 3 authors
As keyree said, it means the message has not been sent. You should be able to tab the message and hit resend or retry. 10-06-2015 03:50 AM.
Meaning of Exclamation Point in a Triangle - texting ...
Aug 23, 2010
how do i get rid of the red triangle with the exclamation ...
Feb 19, 2016
More results from forums.androidcentral.com Missing: Doro ‎' Must include: Doro
How to remove the triangle with exclamation mark ... - AskingBox
https://www.askingbox.com > question > how-to-remov...
Oct 31, 2013 - The symbol "triangle with exclamation mark" in the status bar is a common symbol for a warning. In your case, that is the data usage warning.
2answers
Why does my darango shut off while driving?
If it's an exclamation point inside a triangle, it's called a master warning symbol. This is the Master Warning Light symbol. If this light is on, there will likely be text displayed as well on the instrument panel, or another warning light. Look for text in particular. It could very well point out something as serious as low oil pressure. If the engine is not running, you can't very well check your gauges, but you may have lost all oil pressure or overheated the engine. Recommend you consult a mechanic familiar with your model.
Why does my tracphone have a red exclamation on the home screen?
What does it mean when my samsung tracfone shows a ...
www.askmefast.com/What_does_it_mean_when_my_samsung_tracfone...
What does it mean to have a icon appear on my samsung flip phone with icon little phone with ..... A symbol of a phone and exclamation point on my tracfone screen .... "The main screen that looks like a telephone with a red explanation mark.
Phone symbol W/ RED exclamation point? - BlackBerry Forums at ...
forums.crackberry.com > BlackBerry 10 Phones & OS > BlackBerry Z10
May 18, 2013 - 8 posts - ‎5 authors Now that I wanna take a screen shot of it it goes away. But your answers ... Red exclamation point next to e-mail on curve. By jr369 in forum ...
Exclamation LG 840G Tracfone/Safelink help! - Howard Forums
www.howardforums.com > ... > Tracfone/Net10
Aug 17, 2013 - 15 posts - ‎7 authors From the main screen, press the "Applications" icon at the bottom right of the ... i havethe same phone, can the lg840g be used with safelink?
1helpful
WHAT THE SYMBOLS MEAN
From left to right:
(Lights)
Exclamation point: Error
Weird Monitor beat symbol: Jam
Paper: Out of paper
Toner (Triangle leading down to dot pyramid): Toner refill
Lightbulb: ready
(buttons)
Greenish Play button (square with triangle): Continue
Red button with x: Stop/Cancel
Dell 2230 User Guide Page 1
1helpful
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Best,
Mark
G1 boot up error
when i turn my phone on it wont go to the android area. instead it shows a picture of my phone with a exclamation inside a triangle... ive tried to reset it and it wont go past this.
1helpful
HP P2015DN
If just the triangle with the exclamation point in it is flashing, the printer is sensing the cartridge door is open
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
