SOURCE: Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
SOURCE: my compaq presario v5000 shut down and wont restart
My Presario v5000 is doing the same as above. Except, I let it cool for a little while and it turned on. Now it only turns off after a while. I'm not to sure exactly why that is but i could possibly be an over heating automatic shutdown procedure.
SOURCE: no screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
SOURCE: compaq presario v5000 won't start or post
It's the motherboard. Check to see if yours is still under warranty even if you've had it for over a year.
HP / Compaq has recently extended their warranty period for certain models.
Warranty Check
Let me know if you have any other questions.
SOURCE: Compaq Presario F700 wont boot. Powers up then turns off again a
that means you might have a hardware failure. possible powersupply. check with local shop.
