If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Good afternoon friend, thanks for the post!
I see from your post that your Frigidaire dryer is getting extremely hot on the top and back. Have you checked to make sure that it is getting proper ventilation? I would verify nothing is blocking your dryer from ventilating which could be causing the appliance to heat up. If it continues to heat up I would reach out to a technician to come diagnose and repair your dryer. I hope this is helpful. -Matt
Hello - The following could be reasons for your dryer to stop working; there could possibly be a malfunction in the thermostat in the return, so if it gets too hot on the auto dry cycle, it stops and will not re-start until it cools down. This could be caused by either lint or something else clogging the vent thus causing it to overheat. You should be able to feel the top of the dryer right at the back of the top near the console right after it shuts off. If it is getting too hot to the touch look to the items I have mentioned. Should you find that these suggestions are ineffective, may we suggest contacting a professional to move forward accurately who will be able to diagnose the problem.
