You may want to check out the wiring in this Ceiling Fan Installation page which shows the wiring connections with a switch.
Make sure that when the switch is inserted into the box that the bare ground wire does not come into contact with the terminal screws on the switch.
Make sure you are hooking up the correct color wires to it main wire on top of switch, bottom wire of switch other color wire they should be blackor any other color , just dont hook up the white wire to it this will make your breaker pop , If your copper is touching any metal this will make it pop also,good luck
