Magic Chef CAV2000 Top Load Washer Logo
Posted on Aug 31, 2008
MAgic Chef top loading washer will not spin or drain
We are replacing an ancient Magic Chef top loading washing machine. I need to drain it so that it can be removed, but it will not spin.
How can I drain it?
  • Anonymous Mar 14, 2014
    Samsung top load wa5451anwxaa will not spin or drain
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jan 03, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1280
Points
6
You have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
1helpful
The machine wash but the spin not working. so the cloth stay wet
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
น้ำ รั่ว
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Margic Chef washing machine makes loud ginding noise when agitating and on the spinning cycle.
heatman101
MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
2helpful
My washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Washing Machine Won't Spin/Drain
Apparently, there is an issue with this model. Get it checked out. I did.
Top Magic Chef Washing Machines Experts
Paul Carew
Kolbrun...
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
