SOURCE: clutch rattle
no there is not a kit available. I have tried it myself before and used other spec material for the damper in the clutch and made the rivets myself. Worked great but is very timely. I'd actually recommend buying a new basket. The side pedals on the original basket often get grooves from the clutch plates wearing on them which can cause clutch chatter too.
SOURCE: 1991 Kawasaki KX 250 super tight clutch
Hi!
Help is at Hand (Excuse pun),
This problem described strongly relates to a seizing clutch cable or frayed.
If you remove it try and pull/push the inner with your fingers there should be No resistance, you may get away with a good oiling but I would recommend replacement.
Good Luck!
Paul 'W'
Onyer~EDson(:0) {#><
Please remember to politely rate my effort!
SOURCE: something is rattling in tranny or engine?
Its worth openning again the side cover and re-inspect that nut, not bad too if you can remove the clutch basket taking care of the plates as how they are fitted so that you don't get confused on assembling.
Check for the wear on the basket where the clutch plates go in and are thn driven especially those notches, check too the gear that mashes with the clutch system for any wear and not bad to check the springs too in the clutch basket.
Hope this helps .
SOURCE: how to remove the clutch from my kdx 200
The simple way to do it is borrow an electric impact gun. (1/2" drive) If you jam something in there you can damage things.
