SOURCE: how to use a brother fax- 645 plain paper fax
You may have been given a heap of junk. Happens all the time. Just place the document face down in the ADF and dial the number then press the green button to send.
Testimonial: "good and helpful"
SOURCE: f ed up fax mahine
Is the hand set on correctly? (unlplug it if you can)
make sure the phone line is plugged into the LINE port.
Unplug the power cord for 10 seconds.
SOURCE: My Brother fax 2820 has
That message means that a telephone "somewhere" has access
the line that the FAX is plugged into BEFORE the fax. The most likely cause is
an extension phone or maybe a computer modem (if you still use a phone modem) If you want a manual you can download it here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_2820_2920_MFC_7220_7225N_EN_1344.PDF
