Hi,Here is the soft version of the user manual .. pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in
PDF format.
To download a PDF file, enter the four-digit (or three-digit)
module number marked on the back cover of your watch.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
All Casio manuals are available on Casio.Com. Select support and go to manuals. If you do not see your model then look in the archives. All manuals are available here.
In addition to the Pin there is also a small inner "locking" collar about 2mm long that fits into the center section of each link.
I did not notice this collar at first and it fell to the ground when I removed the first link. Without this piece the Pin's will just slide through the links with no locking mechanism.
It fits neatly into the inner portion of the link directly opposite the arrow that shows the direction of removal on the band.
