Nokia C5 Cell Phone Logo
Posted on Jul 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I transfer pictures from a Nokia C5 to my computer via USB cable?
Anonymous
Level 2:
  • Expert 48 Answers
  • Posted on Jul 29, 2011
Anonymous
Expert
Level 2:
Answers
48
Questions
0
Helped
15021
Points
141
Pl. install nokia PC suite which comes in a CD supplied alongwith the phone. You can easily transfer files including music, pictures and video.
Anonymous
Level 2:
New Friend:
  • Expert 67 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
67
Questions
0
Helped
15485
Points
237
Hi,try to my solution you want to transfer your picture from your cellphone,first step you need a Memory Card, if you have a memory card to your cellphone you can save your files or picture to your memory card,Second Step after you save your picture to your memory card,you get out your memory card from your cellphone and then you need the CARD READER USB ALL in 1,if you have like that you can insert your Micro SD or Memory Card to the card reader,after that your card reader is plug it to your usb port to your computer,and you save your picture to your computer.thats all,i wish that i help you,thanks :)
tip
How to Transfer Pictures or Video from your Cellphone/Mobile to your Computer
With the increasing quality of Cellphone camera's , more and more people are wanting to copy their pictures from their phone's to their computers.
There are basically 4 ways to accomplish this.
  1. USB Cable
  2. Bluetooth
  3. Card Transfer
  4. E-mail
# 1 USB Cable
One of the most convenient ways to transfer your pictures is to use the USB cable if your phone was supplied with one. If your phone was not bought with a cable , you can purchase the cable from the store where the the phone was bought.
You will usually also need the manufacturer's software like Nokia pc suite for Nokia phones which can be downloaded from the website of the manufacturer. Here is a list for the most popular phone brands sites.
Nokia
Samsung
Sony-Erricson
Motorola
LG
Many phones also support the option to use the phone as a flash drive so to speak. When you insert a cable , the mobile would typically ask in what mode to use the cable in for instance : Print , Storage or Nokia mode. If you select the storage mode , you may transfer your pictures from the phone the same way you would from a flash drive.
# 2 Bluetooth
If you are using a laptop or bluetooth enabled PC , using bluetooth can also be a handy way to transfer your pictures. To do this , enable bluetooth on you computer and from the taskbar , right click on the bluetooth icon and select recieve a file.
Then on your phone , go the the picture or video you want to send and select options and send via bluetooth. This will vary from phone to phone , so look around for the send with bluetooth option.
Your phone will then search for a computer in range and once you have found your computer , hit the send button.
The transfer will then take place and your computer will ask you where to save the image.
# 3 Card Transfer
Most phones these days have a removable memory card. This is a easy way to transfer a large amount of content from your phone to your computer.
Simply remove the SD or Micro SD card from your phone (refer to your manual) and insert it into a external card reader or your laptop's built in card reading unit.
You may also need a micro to sd converter which can be bought either with a micro SD card or separately from most chain department stores.
You will then be able to transfer the content like you would from your digital camera.
# 4 E-mail
If your cellphone supports e-mail and it is set up , and you only need to transfer one or two pictures , e-mail can be very helpful.
To do this , go to the image you wish to send and in the options , select send via e-mail. This option differs between brands and models so check your manual. You can then simply send the picture to your PC e-mail address and retrieve the image from there.
Please remember to rate this tip if you found it useful.
Kind Regards
StephanSA
on Feb 24, 2010 • Cell Phones
7helpful
3answers
Transfer contacts from nokia c5 to pc
Problem with Nokia C5 Cell Phone
How do i transfer photos frpm my nokia to my laptop
You can do it in different ways.
If you have a cable for your Nokia cellphone and you have a Nokia PCsuite, then just connect your cellphone to your laptop via the USB slot.
If your cellphone and laptop has Bluetooth, you can transfer your files wirelessly. Just connect them via bluetooth and choose "transfer" or "copy" the pictures you want to transfer then choose "via Bluetooth".
If you save the pictures in your cellphone's memory card, you can remove the memory card, insert it in a card reader, then insert the card reader into your computer.
Thanks for using Fixya!
With nokia c5-00 cell phone the file transfer can not be done even with nokia pc suit cable connection. i get message that the mobile phone rejected the operation
install the USB driver , it will including in CD
search on Nokia web for USB driver for nokia E5. hope it can solve your problem. good luck
How to transfer pictures from hp netbook to my nokia5000 cell phone
Connect your phone via the data cable to the Netbook usb port. Select mass storage on the cellphone if you want to transfer the pictures as you do in a pen drive. Your nokia cell phone will be then listed in My Computer/ Computer as a mass storage device. Copy and paste the pictures to the images folder on the phone.
Or
After connecting the cellphone you can select nokia PC suite and can transfer images using the software. You need to download and install the software before you connect the cellphone.
Regards,
Shrey
3helpful
I want to download music using my usb
Hi,you can transfer music to nokia 5800 from your computer(pc or mac). There are different ways of transferring music.if you have a PC, you can use PC Suite to transfer music files.the nice software that comes with the phone. If you have a Mac, you can use Nokia Multimedia Transfer (free download) and sync it with your iTunes.
how to put songs on nokia 5800-nokia pc suite
To transfer music as data files, make the connection with a compatible USB data cable. You also need to have a compatible memory card inserted in the device. View your nokia 5800 on a computer as a mass memory device. follows these steps: firstly, connect nokia 5800 with computer via USB data cable. then select Mass storage as the connection mode. A compatible memory card must be inserted in the device. then view the device from the computer file manager as a mass memory device. now you can fansfer the music files. after transferring songs, you can close the connection by remove the USB device safely from your computer.
Hope it helped.
Don't have USB driver, how to transfer pictures from Nokia 7210 to Personal computer?
transfer your pictures from your nokia7210 via blue tooth.attach your computer via blue tooth dongle.connect through a code0000 on both the item.now you r ready to transfer your images
16helpful
3answers
How do I transfer pictures taken by my LG CF 360 phone to my PC?
The USB cable does not work apparently, UNLESS you have a micro SD card inserted. You also have to manually transfer the pictures from the phone's internal memory to the SD card first, then you can transfer them to the PC via the USB cable. The USB connector on the phone is one of the new USB micro A or micro B connectors - make sure you get the correct one. It looks like the one on the phone charger.
Nov 21, 2009 • Cell Phones
2answers
Transfering photos from a nokia 2630 on to computer
Do you have Multimedia Messaging support? If so, you can email the pictures to yourself.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
