To set the date on your Jaga digital watch with the WR50M model number, you will need to follow the steps for setting the date on your particular watch. Every watch is different, so the specific steps will depend on the make and model of your watch.
Here are some general steps that you can follow to set the date on a digital watch:
- Locate the stem (the button on the side of the watch) and press and hold it until the display begins to flash. This indicates that the watch is in time-setting mode.
- Use the stem to cycle through the different settings, such as the time, day, date, and year.
- When you reach the date setting, use the stem to adjust the value to the correct date.
- Once you have set the date to the correct value, press the stem to exit the setting mode.
If you are unsure of how to set the date on your watch or if you are having trouble, you may want to consult the manual that came with the watch for more detailed instructions. If you do not have the manual, you may be able to find a copy online or you can try contacting Jaga customer service for assistance.
I don't know how to on/off and set the alarm of My pop art wr50m watch. It just keeps on blinking and blinking when I'm setting it.
