Error code E20 means that the coin trap/drain pump hose needs cleaned out. It can be done by the owner with a friend helping:
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the
back feet are still on the ground. Please make sure the unit is
propped up safely.Or you can lay the unit on its back side.
3. Now that the unit is propped up look inside the hole on the
bottom of the unit - on the bottom right hand side there is a black
looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have
towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is
a silver spring with a silver screw. Loosen the screw and wiggle the
coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Here is to get you fixing the machine; thats your service manual: http://www.mediafire.com/download.php?0gy1jnemjdp
Hope helps.
