SOURCE: friends' yahoo messenger ID blocked.Can't add it to my msgr list!
I have used Zak's nobuddy before - it has been updated to work with yahoo's newest protocols.
Test: (A) I have 2 yahoo ID's - I added each to the other:
(B) I use Yahoo Messenger version 9.0.0.2162
(C) I was invisible mode at all times on each ID
1 I then got this zak nobuddy to remove one from the other:
2 It worked (although it left no message - I was simply gone).
3 I then performed the normal add request - this too worked fine and I was added again as soon as ID2 accepted.
You say it's blocked from your contact list:
I would check from messengers menu bar
messenger/ preferences/ ignore list and see if your friends ID is in there.
SOURCE: your request to add a
Google it and no satisfactory answer, same problem with us and gives us headache.
SOURCE: Add contact to Yahoo Messenger always problems?
Dear Sir,
This is generic problem for yahoo messenger,It is not your computer problem.It is problem associated with yahoo.Some time there network fail to identify the request in a large network. Install latest yahoo messenger,in latest version this problem fixed somewhat.
good luck
SOURCE: Add Rocketmail id in Yahoo Messenger
You'll need to use the entire rocketmail address, so it'd be something like "[email protected]" instead of just "yourname".
if u cant play then u should download it from yahoo site....
after that if u cant open it...means some dll file is missing...
even this cant solve ur prblm plz contact me live
