There is a magnetron that generates the microwaves. Either the magnetron or the magnetron fuse has failed. Either way, as you can purchase a new one for quite a bit less then the cost to repair the microwave. If you wish to repair the unit, please post the model number. I do want to let you know that working on a microwave is VERY DANGEROUS and I would not recommend it. The microwave oven hold a lot of electricity even if it is unplugged.
I see! You have it under microwave ovens. Sorry I misunderstood you.
You will have to re post the question under the correct listing. I do not have access to make the change, Sorry.
Thanks
Hi,you have not stated how old this unit is ? I think they are supposed to last for
4-5 years but I've known some to break after just one year and others
that worked great for 15 years or more.
Read more: What is the average life span (during normal use) of a microwave oven? ' Answerbag http://www.answerbag.com/q_view/1540053#ixzz1TQlW7RlH
Carbon Heating Lamp for microwave oven strong heat resistance. More than 6000hrs lifespan.
From a website...
7.3.7 Magnetron Life Expectancy
The
typical life of a magnetron tube is approximately 2000 hours of
operation. Some factors that can diminish the life of a magnetron are:
1) no-load operation, 2) operating with too much metal in the cooking
cavity, 3) line voltage consistently too low or too high, 4) improper
phasing, 5) improper installation or removal, 6) replacing associated
high-voltage components with substitutes that are incompatible with the
system design, 6) continual operation at the upper limit of its heat
tolerance due to inadequate air circulation, 7) obstruction in the
wave-guide, 8) failed stirrer operation.
We use
ours about 15 mins a day which would mean 2000 hours would be reached in
22 years but as they say there are a lot of factors which may reduce
its life. The design and parameters of the oven will make a
considerable difference. E.G. A highish power magnetron always
underrun will last much longer than a smaller one run at its max
ratings.
A restaurant might reach 2000 hours in only a year or
so and industrial machines whether for cooking food or other processes
will require frequent magnetron replacement.
http://www.alibaba.com/product-gs/439406670/Carbon_Heating_Lamp_for_microwave_oven.html
Hi again..sorry I was about complete my message but something happen and it has gone..Anyway,as I said if you device is older than 5-6 years probably your device's lamp has gone..it is easy to replace it as DIY type..I have sent you an example link (Alibaba ) which has all sort of lamps are available..
To make sure,unplug the oven , try to demount the lamp and mount again to make sure if something were not loosen ,if it does not help go with a new lamp..
Regards
BUT YOU HAVE MARKED YOUR QUESTION AS
" Problem with the AEG Microwave Ovens"
SO HOW SHOULD WE KNOW IT IS NOT A OVEN?
SORRY ABOUT THAT !!!!!
YOU BETTER RE DESIGN AND ASKED AGAIN YOUR QUESTION ..MORE INFO WILL ATTRACT MORE EXPERT...
In order to keep your Tassimo machine
operational at full order, it is important to descale it every three
months. Descaling products are widely available from stores that sell
coffeemakers and espresso machines. Be sure that the product you buy to
descale your Tassimo machine is intended for this specific use only. Mix
the descaling product directly in the water container, following the
instructions provided on the descaling packaging. Then replace the water
container on the machine. Place a large cup or mug on the cup stand,
insert the cleaning disc, bar code down and close the brew mechanism. As
soon as the AUTO light illuminates, press and release the start/stop
button. This will fill the brew cycle with descaling solution. Empty the
cup and let the machine stand for 15 minutes. Then open the brew
mechanism and close it again, leaving the cleaning disc in place. Repeat
this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water
container, rinse it well and refill with fresh, cold water. Clean the
machine by flushing water through it in the same manner and emptying the
cup as it fills. Make sure that all the descaling solution has been
completely rinsed away, and then flush two full water containers through
the machine before using it again. Remove the cleaning disc, rinse and
refill the water container and your Tassimo machine is ready to use.
Also, before you descale your Tassimo machine, always unplug it. Also,
never immerse the appliance in water and nor should you use abrasive
cleaning products or scouring materials on any part of your Tassimo
machine. This method works for most espresso machines,
including some of these popular models: the DeLonghi Magnifica
EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400,
Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi
PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
This is not a microwave problem. I have an AEG built-in espresso coffee maker. The machine seems to go through all th emotions, but the water comes out cold.
This is not a microwave problem. I have an AEG built-in espresso coffee maker. The machine seems to go through all the motions, but the water comes out cold.
I didn't mark it as an oven....seems the system assigned Microwave Oven to it....will someone else try to answer the question?
yes...an error occurred....can you re-direct this to the correct person? Espresso coffee maker....
